2FA Keys Ceasing to Work on Chromebook?
MattDPenn
Greetings all,
I'm curious whether anyone has had issues with a 2FA key ceasing to work on one device yet working on others? In this instance I had one, and now possibly two, GoTrust Idem keys seemingly not working consistently with chromebooks (HP 11MK G9 EE, LTS v126) their users typically use. My Yubikey worked just fine on the chromebooks in question so its not the USB port and I am pretty sure I got the GoTrust key working on a different model of chromebook. I haven't been able to sit down for a long trouble shoot session as the affected users have tight schedules.
Unfortunately the first affected user also hasn't had an opportunity to retest their key after I removed it and readded it via my Windows laptop where it seemed to work fine. They just burned through the couple of one use codes I gave them. Just had a second user crop up today with a similar sounding issue which is why I'm posing this topic. I even tried power washing the affected chromebooks to no effect.
I didn't see anything weird as far as logs go in Google Admin unless I'm looking at the wrong reports. Has Google made any changes to their 2FA protocols in regards to physical 2FA keys? I know they're moving away from SMS to QR codes or somesuch.
I haven't heard anything about changes for security keys.
I only ever use Yubikeys.
MattDPenn
It's looking increasingly likely that this is a failed key. While I was able to download the key management program resetting the key seems to have gotten me an even deader key as now Google Admin won't recognize it at all. Still need to touch bases again with the 2nd user who might have been having a similar issue.
