Unintended or Ghost Click
mpartenope4676
I'm wondering if anyone has noticed a problem with Lenovo 300e Yoga Chromebook Gen 4 and Lenovo 300e/500e Chromebook 2nd Gen devices. Devices updated to 135 or 136 are exhibiting a "ghost click" of sorts where sometimes the bottom right hand menu will open or other windows would restore down. At first we sent devices to repair but quickly we went from one instance to 12. I stumbled upon a thread or two here where admins are limiting the OS to Long-term Support (LTS) (more on this here) I found this to be an excellent idea and have made that change, but the damage is done for devices of this model one 135 and 136. I adjusted a "Rollback" OU I made ages ago to do what the name suggests. I only had a test Acer on hand and it worked when I performed a rollback. The 2nd Gen devices also work without issue. No matter what I do, the Lenovo 300e Yoga Chromebook Gen 4 will not rollback. I had to use the recovery extension tool to create a recovery USB. There are advanced settings where you can select the Long-term Support OS. Once I did this, the device was on 132 and the ghost click ceased. I have a support ticket open with Google but is anyone having either the ghost click issue or issues rolling back devices or both?
mpartenope4676
Google was completely useless when trying to figure out why the Gen 4s couldn't roll back. Thankfully, installed the LTS Candidate of 138 fixed the ghost click.
