Blocking Chrome settings
kcalderw
So I have been going over our blocked settings policy. Currently all OS and Chrome settings are blocked via URLs. I am testing using the Disabled system features option instead which seems to work fine too. The problem we run into is Bluetooth. Is there any safe way to open up Bluetooth settings for pairing without also opening up the entire OS-Settings as well?
I have had OS-Settings blocked for years because even if you allow os-settings/bluetooth then that allows students to just browse all the other os-settings as well negating the original block on os-settings.
