Block Google Drive domain
This may have been asked (most likely has been, maybe even by me...) but is there a way to block an entire domain from sending any communication (email and Drive) to us?
I've reached out at least once before to someone in their IT department but I just want to block their domain now from sending anything to us. It's in a geographically distant region from us.
Any way to do this with Edu Fundamentals? I suppose the other option may be to use our Proofpoint to block "Header ReplyTo" and do a wildcard on their domain.
Incoming Gmail
Yes, both Routing and Content Compliance rules should be easy to block that.
Incoming sharing
This is a lot harder if you allow any incoming sharing. I'm fairly sure that it still can't be done. I don't think Drive Trust Rules are flexible enough, or even affect incoming sharing at all.
Thanks. I've created a separate compliance rule for this domain.
On a side note, is there any ability outside of GAM that you can pull (delete) emails that users received? I have used a combination of Proofpoint/Gmail log search for the Message-ID and then export the list of users and perform a GAM command to delete the Message-ID from that list of users. Just wondering if there's a way to perform that from within Google Admin. We have Edu Fundamentals, so maybe the Investigation tool is the tool to perform this, which we don't have?
Yes, the Investigation Tool can do that, if you have the appropriate licence.
