This is very common and not the least strange.
This is an app that some user has logged into using the Login with Google button. As there are 100s of millions of apps, using Google login, there will be many such examples.
This is absolutely not something you should allow.
That's also why the proper process should be to go through the list of accessed apps and only Trust the very few apps that you know everyone should have access to, and then set the default setting to Block everything.
Everything else that people need you will quickly learn about, as people will immediately be blocked from accessing them, and will reach out to tell you about it. Preferably, they should reach out through an already existing process for "request access to new apps, services or extensions", where you can properly vet them before allowing, or denying access.
