Extensie automatisch in- en uitschakelen
Kristof
Dag iedereen
Onze school wil graag dagelijks een extensie uitschakelen na schooltijd en bij de start van de schooldag terug inschakelen. Heeft iemand weet van een (eenvoudig) script om dit te automatiseren?
Alvast bedankt!
Kristof Van Dyck
Even though I know it's technically possible, I can't recommend you even trying.
There is no guarantee that such a change will take effect faster than 24h.
That means both when you set it to be disabled and then when you set it to be enabled.
This means there is zero guarantee that the extension will be enabled or disabled when you want it to.
Never.
From experience, we know it usually takes effect faster, but we also know it can take up to 72h, even though the documented "guarantee" from Google is 24h.
