I recently explored the Gemini API which is a powerful tool for integrating artificial intelligence into applications. It allows developers to generate text, build chatbots and analyze data efficiently. Gemini API makes it easier to create intelligent systems without building AI models from scratch. It is useful for students and developers who want to build AI projects, automation tools, and smart web or mobile applications. Excited to explore more and apply it in real-world projects.
Yes, different resources are available like you use API from hugging face, openAI API this is where AI projects form. If you learn API in python then freeCodeCamp helpful in it
lingoThreadLangSelected(lang, '208874');
var getTranslation = lithiumPlugin.getTranslation(lang, "208874");
